Quote by William:
"you have a open-circuit(possitive +)sorce which supplys voltage to the ALT-voltage regulator,the A/C compressor clutch,and coolant fan motor.The dash lamp is displayed because on start-up,with the key-on the lamp takes a ground from the Alt-regulator circuit,until you start the engine then the lamp goes out due to the regulator in return sends battory voltage back to the bulb on the same circuit.Which is how the light stays out when the engine is running or till there is a system fault in the charging-system.As one "other" pointed out on this post,check your fuseable links(****-fuses)also coolant fan motor connector(the three wirer connector may be melted together-due to a shorted fan motor)Check the harnnes also running back to the fan relay center,and the harnness to the Alt, for a short to ground,also the Alt it self may have a internal short.Wm"
I'll post a pic tomorrow, but my main fan relay looks like someone has been stick welding in there. This, obviously, is a contributing factor & explains why it only happens some of the time. There is a loop from the main relay to the fan speed relay, & I'm guessing I'm shorting everything out when a certain fan speed kicks in. Looking at the relay center from top, the bottom left relay's bottom connection, gray wire, is what's now an integral part of the plastic relay housing. Melted together solid.
My main concern now is what caused THAT to happen, or is the root cause elsewhere. I'll follow up by checking the fan wiring harness and connector. I inspected the alternator harness when I took the alternator off. I'm assuming I don't have a short in the alternator or it would have showed up on test?
Will folllow up tomorrow. Chuck Tator, I need some parts.
Thanks for all the input guys. HP, next time I pull through Little Rock on the way home, I owe you lunch.
