Got the petal to the floor in third gear coming to a 25MPH turn at about
90MPH
took foot off gas pedal car still pulling like a VIPER Holy S!$t!Tryed the brake NO HELP
Had trees on both sides Did not want to turn ignition off running out of time I Slammed the Brake and Clutch petals both at the same time hoping that the motor would not come apart. All of a sudden the gas let go and the car came to a stop and the motor was just idling
Pulled over to see what happend? I found that when you have the pedals
extended out as far as they go and you have an aftermarket SRT-10 floormat
that the gas pedal gets wedged into the floor and by stomping on the brake and
clutch pedals it gave the pedal cluster just enough of a shock to release
the gas pedal.
Just hoping this does not happen to any one else!!
90MPH
the gas pedal.
