Tom F&L GoR
Whoa! On any other car you might be correct, DrDJ. But the OEM calipers on a non-ABS Viper are too front-biased, so heavy braking is limited by the performance of only the front brakes. Or you may find the fronts too easy to lock up and flat spot the tires. The rears do not do enough work.
Stoptech has a front-only kit that provides a caliper with four smaller pistons, effectively required an unnoticeable amount of harder brake pedal application, but shifting more of the total work to the rear.
Stoptech also has, as does any other 4-wheel kit, excessively large calipers for the rear which you dial down using the proportioning valve to get proper front-rear braking. Same for Dave's SRT conversion - large rear caliper that looks great and is used at about 25% of capacity.
The OEM caliper can be enlarged from 36mm piston diameter to a 40mm piston to also get proper front to rear braking. This simple change (and the ones above would be similar) resulted in a stock '94 improving from ~0.8 G's to over 1.0 G's braking using street tires.
Once you have a four tires doing as much work as they can (which won't be equal, the fronts still do more) then the heat capacity of the brake pad comes into play.
