What is your 1/4 mile time???
Gerald Levin
Indianapolis, IN
My car is bone stock and if I got a good nights sleep, made a few hundred passes on the track, I could probably post a sub 18 second run.
Gottaviper
Boston Ma.
I felt I did pretty bad yesterday at New England dragway
12.507 @ 115.82 mph
Smooth tubes and filters, Edlebrock headers, Roe oval cats and side exhaust and 3.55 gears
Mastiff
Medina OH
11.99 at I think 120mph. I cant remember the exact speed. 99 RT/10 bone stock except for random tech exhaust. Air temp was about 45.
vipeuup
OR
12.507 @ 115.82 mph
dang, were you holding a cup of coffee on the other hand? :D Your car should be in the mid 11's....
GotAViper
Annapolis,MD
12.507 @ 115.82 mph
mid 11's with those mods? It's a 94 correct? I have the same exact mods and I am looking to get low-mid 12's. I don't see mid 11's with those mods though. What kinda tires are you running? Im running michellin and dont see 11's comin with those on.
vipeuup
OR
12.507 @ 115.82 mph
sorry, didnt see that it was a 94 :D
Gottaviper
Boston Ma.
I was hoping for an 11.9 but we got rained out after two runs so I could not practice my launch. 60' was 2.005 I think I can get that to 1.8 but maybe I am wrong. I have michlen pilot sports and did not use the water pit
GTSnake
Motor City
I have to rerun my times with drag radials. The whole time down the track I was slipping in each of the 3 shifts.
Ivory
Madison, WI
Don't know, but my car did 525/704 at the wheels on the Dyno. What do you guys think it will do in the 1/4?
2MANYTOYS
North Carolina
Anaconda
Impossible to answer. That depends on track conditions, driver ability, etc.
Crappy driver in 100 degree heat on a poorly prepped track is going to be worse than a good driver at like 70 degrees on a properly prepped track.
orlandov10
11.5 @ 125 with my Roe Supercharger 1999 GTS, Spinning on the original tires, my car was misfiring up above 4700RPM as I had the plugs gapped too low. Going to go back out with the N20/Propane and drag radials soon.
neat
Tough to say. With a everything perfect, a high 10 is certainly possible. Don't be dissapointed if you go out and run 12's though.
Seems like almot every Viper I see at the dragstrip only ever comes once. The owner normally expects these killer times, and goes home dissapointed, never to return. Don't get down on yourslef, or your car, if it doesn't run the times you were hoping for. Just get back out to the track and practice! No one comes out and busts off 10's there 1st time ever down the 1/4.
cookviper
