What type of Mobil 1 and filter recommendations:
georgekessel
Vancouver BC Canada
Hello, I'm about to run out to pick up some Mobil 1 to change the oil in my 96GTS. What type/vis. of Mobil 1 should I get and will a good FRAM filter be fine for her?
Viper Wizard
South Salem, NY USA
Mobil 1 : Tri-synthetic Formula 10W-30 [Green Label]
Filter : OEM Part #5281090 or Mobil 1 Premium "Mopar Performance" Part #P5007550
DO NOT USE A FRAM!
Gavin
Monterey, Ca, USA
The O-ring rubber seal on the top of the Fram filter is held in place by either four or six tabs - it can and will blow out.
The Mobil 1 filter - the seal is held in place with metal around the entire edge if the seal.
The Fram has less filter material than Mobil 1 filter - hold one of each in your hand - Fram is larger filter but much lighter.
I have been told, use of non-factory recommended filter will void your warranty - not sure if that is fact - why risk it for a few bucks
Our Viper tech - Ted May - recommends 15-50 weight Mobil 1 for vehicles running the track
Steve Miehe
Cincinnati, OH. USA
On second thought, maybe I won't. You would think that the factory filter would use good quality material and be engineered properly. Guess not.
gavinpeng92
