Where can I get injectors and fuel rails?
GTSnake
Motor City
Help. I've checked Parts Rack, Mike Adams, Roe Racing, even Henesy and can't seem to find larger injectors.
Can anyone tell me where to get some? I've heard Heffner but so far still no luck. Is there some reason why no one sells them?
1TONY1
Dalton Ga. (Chatt. Tn.)
If you are getting fuel rails, I assume you are going to the top feed injectors instead of the stock type side feed ??? If so, ford and some GM injectors should work.
GTSnake
GTSnake
Motor City
newredrt10, I'm thinking 48-50lbs. Something to match a supercharger.
1tony1, how do I reference which GM or Ford injectors? Do you have any part numbers? Did you change your injectors for your Roe SC?
Sean Roe
Jacksonville, FL
Um, we have larger injectors, but our rails are made specifically for the Supercharger kit.
Do an internet search for Viper injector rails and you should come up with something from a machine shop that fits the stock manifolds.
Regards,
Sean
1TONY1
Plain ol' Mustang injectors of whatever size you need. The fuel rail will have to be custom made but that is easy for folks that do fuel rails. Some of these tuners have them done by someone that are already used to doing longer/five hole fuel rails. You need to give me a call, I will pm you my number.
GTSnake
GTSnake
Motor City
Sean, I didn't see any injectors on the website. What sizes do you have and how much?
Sean Roe
Jacksonville, FL
We have Bosch injectors that flow 50 lbs at 55 psi for $42.95 each.
There's a lot of things we have that are not on our website. I guess we need a new site?
dansauto
gillett, pa, usa
Great price on 50# injectors!! I paid $52 ea for Delphi 50# injectors! jim at Reichardracing had 20 sets of rails being made up right now. Sean will the Vec 2 work with a gen 1?
