Where did the hp come from
Jack B
NE Ohio
A while back I posted pictures of a homemade custom air box that seals to both the naca duct and the high pressure area of the grill. Here are some interesting details. I have not dyno'ed yet, but still have some results. I had a hard time dyno'ing last year due to the nitrous, we couldn't keep it on the wheel. That was solved by road tuning using a logger and measuring the slope of the rpm curve. If you can accurately measure the rate of rise of the rpm curve you can calculate hp. In my case the logger has a built in accelerometer and the two quantities can be cross checked.
Here are some facts, in third gear (2500-5000 rpm) with 3.33 gears and level ground with two people aboard the car did the following:
NA: 546 rpm/sec
100 shot: 650 rpm/sec
200 shot: 710 rpm/sec
300 shot: 865 rpm/sec
325 shot: 900 rpm/sec (52 to 87 mph in 2.2 sec)
All runs needed drag radials, except the NA runs. These are all averages of several runs at each level.
These are all repeatable numbers and have been logged mutiple times, sorry about the long route here, but, this is the interesting part. Over the winter the following was done:
1. We fixed a vacuum leak caused by the shop that did the head porting. They never milled the intake side of the heads after milling the block side.
2. Had the intake matched to the heads.
3. Installed the sealed cold air box.
All of these should notadd that much hp, but here is the data:
638 rpm/sec with 3.07 gears, whereas in NA previously withh 3.33's it went 546 rpm/sec. This was the average of three runs. The 638 is comparable to a 100 shot which was 650 rpm/sec. Even if the rear wheel 100 shot was 75-80 hp, these simple mods brought 60-70 hp. What is interesting, when the car is floored at 2500 and starts accelerating, when the car reaches approximately 4300 rpms it feels like the car drops into another gear. On all three runs the tires (pilots) break loose at 4300 when it hits that spot. It shows up on the log also. I have to think it is the cold air box. The car ran one full point leaner than last year across the full wot curve, with the vec i brought it back to about 12.8.
The final point, all last year the logger showed the IAT approximately 20 degrees higher than ambient with the cones. This year with the sealed box the IAT is 5 degrees hotter than ambient.
Ulysses
San Diego, CA. USA
I think you answered your own question :2tu:
Schulmann
Canada
JackB list all the mods that you have on your Viper so we can estimate your base torque before Nitro. But your numbers that you listed looks right given your diff.
My Viper with the supercharger has a street torque around 659 rpm/sec (3rd gear, 3.07 diff, 3700lb viper, stock tires, 60F temp). Which is around 600lb torque and 601hp on dyno.
My biggest gains are generally from:
1. Ignition tuning, depending on what fuel I have, up to 10-15% gain.
2. AFR adjustments, Depending on the air temperature I have to do the adjustements myself since my poor PCM can do it right. Up to 10% gain.
3. Engin temperature. Usually after 5-10 runs on hwy I can't get out more from the engin due to its temperature. I do too many stops between the runs which leaves enough time to the engin to transfer all of its heat to the Supercharger (up to 5% loss).
You leave in OH. Its winter there too. So I presume your gains are temperature related.
J
Jack B
NE Ohio
Schulmans:
the car was doing 580 ftlb NA and about 1000 with a 300 shot.
