i have SVS on mine. i think its the best shifter you can get
MGW shifter on ebay link: Not mine just FYI
eBay Motors: Dodge Viper MGW short throw shifter (item 160170210092 end time Oct-23-07 08:41:59 PDT)
After reading some of the other threads, it looks like there may also be some shifting improvements to be had with the poly motor and trans mounts since they keep things from moving around on you while you are trying to find the gear. I think that will be my next upgrade.
I agree with this Ken. I installed the SVS shifter and it made shifting more precise than the stock shifter. However, under acceleration my shifter seemed to bounce all over the place and I would miss the 3-4 shift a lot. I installed the poly trans mount and I have yet to miss the 3-4 shift and the shifter stays put. Very solid and precise now. Worth the $35/$40 and since you'll be working under the transmission while installing the SVS might as well install the transmission mount.![]()
Which is the same as this one btw. I've got one on mine![]()
The link results in this part number:
ENS-3-1108G
That indicates a GM part, is this the right part number?
