Short shifter options these days?
killerviper
Houston, Texas
Hello Viper folks,
My shifter is the good ol' 2-foot-long stocker on my 99. I understand that a lot of the oldschool short shifter and shift knob options are no longer present. Any vendors these days selling the short shifter and shift knobs? I see IPSCO has a short shifter option which I was looking at.
efnfast
Canada
I installed an IPSCO on my 01 a few years ago .. fantastic shifter, 10/10. Easy install, good short shift feel.
Kittykittykato
Edmonton
I had an Ipsco for my 1st Viper and it was great. But i heard many people say great things about MGW as well so for my 2nd Viper I got one from the Viper Store. I haven't installed the MGW yet. With any short shifter you choose, the Venom mod is almost a must add on.
The stock shifter is smoother and has more leverage. Short throw shifter moves the fulcrum point up. Or, you can move the knob down and get more fork movement per inch of throw with higher effort. I've tested several intermediate shaft lengths and went with mid-length and stock knob on the IPSCO shifter. For me, it's the best combination.
killerviper
killerviper
Houston, Texas
Thanks everyone! I think I'll spring for the IPSCO short throw. - just got their power steering pulley+bracket assembly
Do I need to get the knob lowering kit or was that for lowering the stock setup?
What are my options for an aftermarket shift knob out there that'll be compatible?
Old School
North Alabama
My recipe for a short shifter was cut the head off a bolt the length I wanted it to be, then cut threads in it to match the pitch of the shifter knob I wanted to use.
serafins
Metro Detroit
Honestly you might like a Gen 4 knob (1" shorter shaft than Gen 2, colored stitching, otherwise identical) on the stock shifter. Jon B had some on his site this summer when I bought mine.
If you do want a new shifter IPSCO is the way to go.
I put the Gen 4 knob on an IPSCO with the 1" drop adapter. So I have 2" of total drop. Tried the 2" adapter (3" total drop) and it was too low. 2" drop is just about perfect for me.
killerviper
killerviper
Houston, Texas
killerviper
killerviper
Houston, Texas
Did some more research and wanted to clarify: Can I just use the "IPS13X Shifter Knob Lowering Kit" on the stock shifter assembly and aftermarket knob?
If so, what are the advantages of buying the "IPS426 Short Throw Shifter" assembly?
Prefer going the best bang for the buck/minimal changes from stock.
Old School
North Alabama
Well if you want the best bang for the buck, do what I did. Cut the head off a bolt and cut threads on that end. Custom length, whatever you want. Seems like I did metric on one end and SAE on the other.
Speed Dawg short shifter for Vioers and their Dodge licensed Viper knob…that’s what’s in my picture above.
chris2298
