Hi, My wife just told me she forgets about car stuff not house stuff though. I tried the factory reprogram and even put used boxes in it the keyless and sam box. I tried grounding out the positive battery cable which did not work but I did on spare tire rod which might not have gave a good ground. I'm going to retry on the frame when I get to Louisville. I also bought the course the tech would have used for trainging in 92 and may try to back out a wire it says drops to 0 volts when key fob is pressed which should do the same thing. I would like to get it running before going to dealer as I do not want it towed. I'll give you a call son. Gene
