I'll be doing the same to my 1999 car with 14"srt brakes all around . I'd start with the knob turned out completely [ counter clockwise] for minimum bias to the rear. Find a suitable country road with no traffic and start with front wheel lock up . Adjust the valve turning in incrementally to find good balance between front and rear. It would be best doing this on a track obviously ,and preferably with help of someone with experience .Just like with motorcycles using mostly fron brakes with engine brake , it's safest to have more bias to the front , probably 70% front 30% rear.Some local experts should chime in on this one. Also , I'd like to know if the two wire sensor on the OEM unit is for low brake fluid warning , since the Wilwood unit doesn't come with an extra port for this sensor.Possibly a 'T' fitting requred to add ,so a light in the info gauge won't stay on forever
[/QUOTE
if this is the case is there a way to fool the sensor so the warning light stays off rather than trying to fit it back in the system?
