Wiper Arm Removal - Help
ViperJoe
Virginia
Need to remove the cowl cover to replace the plug wires......
Removed the nut on the wiper arm base.........tugged, pulled, twisted, etc........didn't want to resort to a puller yet.
Any tips?
Use a small battery terminal puller...they often have the tips covered with plastic to prevent damage...have used one many times on our Vipers with NO problems.
Asp Man
Kelowna B.C., WEStern Canada
Try a little liquid wrench or similar around the stud. It should just pull off (I know you know) with v.little effort. Last time I had mine off ther was no issue. Aside from something being bent, I can't imagine why they won't just pop off.
GTSnake
Motor City
I thought the same thing when I removed mine.
You just have to pull hard and straight out. I took a screwdriver wrapped it in a cloth and used it as a lever. Work your way around it a little at a time but it will come off.
