2 Post Lift Contact Points
TexasPettey
Austin, Texas
I've got a 2 Post Rotary installed and I'm working on setting car placement and lift points. Outside of the 4 emergency jack points off the side sills, are there any lift points that folks are using on a Gen1/Gen2?
Viperless
MN
What Boxer12 said. :2tu:
malcoll
Jacksonville Florida
Texas....what did you do to install the 2 post? I am leaning towards the 2 post as I want the lift for working on my cars (brakes, suspension, transmission, oil changes, etc), not just for storage......but I am wondering how much I need to do to install a 2 post to make it safe.
Thanks,
Lance
JoelW
In a Tennessee hollow!
Thanks,
Lance
You need to be sure you have enough concrete depth - at least 4 inches and better with a bit more. And, this should go without saying, it needs to be plumb and anchored well to the floor. Also, buy a quality lift. Many are made in China now and they are just junk. Also, Vipers are very low so you ought to check the floor to lift point height so you can get the lift under your car. Go visit some places and see what garages have.
T
TexasPettey
Austin, Texas
I had the lift installed by the company I purchased it from. The install wasn't tough, and I could have done it. However, he only charged me $200 or so for install. At that price, it wasn't worth my time. The biggest pain I could see was making sure that the holes were drilled correctly and that the lift posts were level. He had a couple of tricks for doing it easily.
As to safety, the depth of the concrete and the PSI rating are the two main issues. Check with the lift manufacturer on the requirements for the lift, but 3000PSI concrete is pretty typical for most recent construction. The other issues are ceiling height and clearance to the walls on either side. I ended up chalking out my positioning of the lift in the garage to make sure I could get it in and still have clearance to the walls and the other car.
I did Rotary for my 2 post. Mohawk is another one I looked into, but much more expensive. I wanted a Made in USA lift.
FLATOUT
I have a Direct Lift Pro 10D and love it! I use the standard jack points under the sills. Lift is a 10,000lb asymmetric 2 poster and the Viper feels like a feather on it.
Andy Wheeler
miwr
