Shandon
I got my B&M Shifter from JohnB. The install was slow but straight forward. The only problem I ran into was not having a 3/4" bit.
My opinion as a fellow viper owner is:
1. The shifts are truly a bit shorter
2. The height is a lot lower than Oem even with the MGW First Strike knob
3. The feel is sharper finding the gates when shifting
I took the car out Monday and put 30 miles on it running through the gears just to be sure I actually could tell a difference. It's hard to know if things like a shifter realy make much change or not. Just because it looks cool doesn't mean it's a functional upgrade. So anyway I did a lot of stop lights and hard freeway driving
. There realy is a difference and the best description I can give is that all the gates feel a lot cleaner/sharper. The 3rd to 4th shift is way improved!! I never had problems before with 2nd to 3rd as some have mentioned but 3rd to 4th especially at high RPM when the engine/trans torques over hard alsmost cought me before at the track. I took the car up to 5200rpm and dropped into 4th and the shifter realy makes it feel like a cleaner engagment over OEM. If there is any downside to the shifter its that it vibrates a little more but frankly who cares. So anyway I feel this was money well spent and if you have ever missed a shift I can attest that this will help with the feel!!
Give JohnB a call and pick one up!
