Nine Ball
Went to Houston Raceway Park this past Friday night while the SRT10 is still 100% stock, down to the air filters and tires. 3,810 miles on it. Weather was in the upper 60F temps, mild humidity.
Best run was:
12.34 @ 118.3, lame 2.09 60' time
I had to basically semi-bog it off the line to avoid spinning and wheelhop, and shift it early on the 1-2 to avoid more violent wheelhop. This thing needs some better tires, run flats ****. Track prep wasn't too great, mostly street tire cars like me. Unlike the LSX engines, you cannot hot-lap this car effectively. The aluminum intake just holds the heat and the trap speed would drop about 1 mph per pass. I got there early and did four passes in a row (no waiting) and it went:
118
117
116
114 (stayed in 3rd)
Gearing is pretty awful for drag racing with the 3.07 gears, and I had the choice of tapping the rev limiter in 3rd near the finish line, or shifting to 4th about 100 ft from the line. It makes a noticeable decrease in acceleration going into 4th since it isn't in the optimum powerband yet.
raceweight was 3,610 lbs. I weigh 192 lbs. The exact same weight as a stock 98-02 Camaro/Firebird. It is really a shame that Dodge didn't make these cars at least 200 lbs lighter. It is physically smaller and has two less seats than a Camaro, it should also weight much less.
I didn't go expecting an 11 on the run flats, but I would on drag radials. Anyways, this just serves as a baseline for me, as I'll begin to modify the car now. Leaning towards Paxton and exhaust.
Tony
