BC Racing DS Coilovers - Anyone Running These?
Octane11
Waco, TX
I was ready to order the BR Series from BC Racing, but in reading about the DS series, I started to research and can't seem to find any Gen 2 or any other Gen Vipers that are running the DS instead of the BR. The DS uses a digressive piston that should help with dampening at low and high piston velocities. It costs a few hundred more, but I'm wondering if anyhone has used them and what their experience was.
Been trying to reach BC Racing for 3 days and can't get a hold of anyone. The web chat option gives me generic answers. Any insight would be appreciated.
Dan Cragin
LA, CA
I've found the BC product on the low end of the suspension market. It does give you the ability to lower your car but the shock does not really control the spring very well and
tends to be over sprung and under dampend. Product support is poor. A much better choice than Aladan's. You get what you pay for.
The best choices for the Viper in my experience are MCS, Koni, Penske and KW. I prefer MCS as the shocks can be built for the spring rates you are going to use, which gives you more adjustability either way. They also have several options, single, double and 3 way adjustable to suit your application and budget.
InTheZoneAC
If you have different spring rates options then how can it be oversprung? And if you have dampening options that you can adjust whenever, how that would make it under-dampened? I'm not saying BC is best for track use, but for my DD (knock on wood) they've lasted much longer than my skunk2s, and I haven't had any premature wear on anything that I can see and I've put probably 100,000 miles on them so far.
Dan Cragin
LA, CA
If you choose the spring rates that are best for your setup, then that is the way to go. The problem is the damping on these shocks is pretty crude and they don't control the spring well, so you need to run a heavier spring rate so everything works. That's why I say oversprung and underdampend. Also, the rear shock is limited in travel, more so when you lower
the car, which can be dangerous.
Don't get me wrong, I'm not saying this is a bad product. They even say its not really a track system and things may have changed some since when I worked with them to develop this system. Its an option for those who need new shocks and/or want some adjustability.
I can tell you, if you are able to drive a car even with a base MCS, or properly valved Penske system, you will know what I'm talking about. Its night and day.
Just my experience, your may differ!
EastCoastSRT10
Maryland
My advice for anyone going to get BC Racing, is ti spend a few hundred extra and get custom swift springs and a revalve from Redshift Motorsports.
They offer different levels of revalves from street to competition for the BCs.
Many guys run them on Solo Nationals and GRM has good things to say about them.
I have a set on my Viper, valves to match my Swift spring rates. Car is very planted and I have no complaints.
I’m sure a set of MCS or Penskes are probably better at the top degree but for most people I think these are good.
They provide a dyno graph of each shock so you know they put in the work to match the rates and the performance.
And the best part is they only cost a few hundred more than a regular set of BCs. For about 800 extra bucks you get custom valving matched to your chosen spring rates and tested on a shock dyno with digressive control.
Dan Cragin
LA, CA
If you want to go in that direction I would suggest Wil Thorne at Snake Bite Performance. He is a BC and Swift dealer and may work with Redshift.
white out
The Mitten
BC does not offer a DS damper for the Viper, only BR. On a different application I was not a big fan of DS for street use and swapped it back to BR. If you have any questions, do not hesitate to message me. I have put 50k miles on my personal Vipes with BC, assisted BC in the development of the GEN2 coilovers, built custom BC for various owners' needs and sold plenty more.
