Best 60' Times with Stock Rearend??
GO 4LO
Cincinnati, OH, USA
Best 60\' Times with Stock Rearend??
Hey, guys,
Just wondering what the quickest 60' times are with the stock independent rear. I just read that SW is pulling down 1.4x's on his stock chassis C5. Any Vipers out there with similar power numbers to SW's Z07 getting 60's like that? Albert? John H.? Doug? Any input appreciated. Thanks.
Chris
RoyV101621
Indiana Suburbs of Chicago
Re: Best 60\' Times with Stock Rearend??
Switch to drag radials and match a 1.4 with the stock IRS. The standard street tire will get you a consistent 2.0 Of course all this depends on conditions and your driving ability. Some do better.
G
GO 4LO
Cincinnati, OH, USA
Oh, yeah - SW's time was with slicks. Forgot to mention that :rolleyes:
. I need street legal tires, though. Would a drag radial (like BFG) or M/T ET Street give you a better 60'? What would be the best drag tire that will remain street legal? Thanks.
Chris
G
GO 4LO
Cincinnati, OH, USA
Albert, what size M/T's do you run? Do you run skinnies up front then?
Chris
jp
Umea, Sweden.
My bests so far is 1.59, but I'm still learning...Launch rpm about 1200, will test higher launch rpms next race.
That was with Drag Radials, Eibach springs and Koni SPA-1.
jp
Umea, Sweden.
I forgot to tell that I was using the stock 3.07.
G
GO 4LO
Cincinnati, OH, USA
Wow, those are some impressive times, guys. I guess I hadn't paid that much attention to the Viper's 60' until I saw SW's time! John, you mentioned that Norm's Viper has lower gears. How much does that help with the 60' when you're dealing with engines as torquey as these? Also, which would be a better setup for a Viper running 150 or so in the quarter - 3.07's so that you can finish the quarter in fourth, or 3.54's/3.73's so you're running fifth by the end? I'm assuming a 1:1 fourth gear - hope that's right. What are the gear ratios in the Viper tranny? Thanks - sorry for all the questions
Chris
G
GO 4LO
Cincinnati, OH, USA
I forgot - one more question for Albert: Do those 16" rims fit over your brakes okay? Do you have stock brakes or did you have to go to aftermarket to get 16's to work okay? Thanks.
Chris
SKY1960
