Big Al
I have a 04 and want to permanently install my CTEK battery tender under the hood or by the battery. Which is the best location and does anybody have a picture of their install? I did a search and did not find any pictures.
Blk n Blu is correct & he got the idea from Crazy Jorgensen who came up with this method about 4+ years ago. It sits back in the back, is unnoticable , and just plug it in through the slats in the rear fascia. Not unsightly , easy to get to and perfect for those hibernating States.
Agree with Paul too, probably a good idea to put a note on the steering wheel, regardless of the set-up so you don't wander out of your garage all hooked up.
I would have to be blind driving away with the cord attached, especially being plugged in at the driver's side gill.Some people don't like simple solutions obviously
With only the pig tail on the car, I can use the charger on other vehicles during summer.Blk n Blu is correct & he got the idea from Crazy Jorgensen who came up with this method about 4+ years ago. It sits back in the back, is unnoticable , and just plug it in through the slats in the rear fascia. Not unsightly , easy to get to and perfect for those hibernating States.
Should be a lot of smart people on this site...if you put the charger permanently on the car, doesn't this affect its safety and longevity, such as water splashes up under the car, bumps and jars ?? some severe weather changes ?? Just put a simple plug (like you buy for a small trailer, I think it is called a blade plug) and plug the charger into this plug, and when I have used an extension cord around the car, I run the cord through the driver's door, to make sure I disconnect before "flight" ...my $.02
+1. I don't understand the reason for having any other method.No notes needed or worries about driveing away while plugged in by doing what I do. I bought the optional cigarrette plug for the tender and simply plug it into the 12v adapter in the side box between the seats. You only have to leave one window down just enough for the cord to clear and hang out. I leave it on the drivers side and works great.
I'd rather take weight out of the car than adding some .Pigtail only for me.
