JUCD VPR
I'm looking to buy a short-throw shifter for my 99' RT/10 in your opinion what shifter do you prefer? Does anyone have any pics of their shifters? Thanks
Two options
1) Shorten the throw with an MGW shift knob ($75) and a shorter SS shaft that you can get from places like Rich Detert ($25).
2) Replace with a complete shifter assy from B&M, Hurst or SVS for around $250-$300 plus install.
Two options
I did both actually.
Two options
Technically not until you have actually installed the parts![]()
Actually, there's a choice "1b" - shorten the factory shift knob/shaft. Its not that hard; just unscrew it then cut about 1.5" off the shaft then re-thread it (or have it re-threaded). This is what I did.Two options
The spring set up helps for good shifts,especially into 3rd.I love my B&M.
Hmmmm... Don't know what the deal was, then. I never had any problems with my gen I shifter, until it failed. When I put the B&M in, while it was crisp, etc and a fine shifter, I did find myself almost missing shifts where I never had any problem before. Perhaps it was because I was simply used to the stock shifter - I didn't put the B&M on until 60k miles, so I was very used to the original shifter, and the B&M was enough different that it was problematic to me - I had to fumble a couple of shifts on the track at Laguna Seca, which really stuck in my mind as a detraction.Randy,
Have to respectfully disagree about your Gen 1 generalization. By far, the best mod I've done to my Viper was changing the shifter. I chose B&M and couldn't be happier - nice crisp shifts, no guessing what gear I'm reaching for, and a very short throw with the MGW First Strike knob.
