BLEW REAR TIRE AT 75mph
3snakes
on a three lane rd. at 75mph. tire blew. spare work good to grt home. anyone had this happen to them?
3snakes
i think i running tire press to low 26pls. i will be repiacing both rear tires
slaughterj
Now how does Twosnakes happen to reply to 3snakes?! ;)
Put your rears at 29psi, but I doubt that 26psi would have caused a blowout - I've run higher speeds while unknowingly having lower tire pressure (unknowingly due to a screw in the tire) without a problem.
3snakes
yes it was no weather checking on tire. had 14000mi. on tires
3snakes
hi three snakes. the side wall came off all around like it was cut with aknife. i was told low air would do this
Ron
Indianapolis
A tire pressure monitor system is an easily installed and wise investment with low profile tires like ours.
3snakes
your right were do you get one do you have a site ?just order tires 365 per tire. oh well
95Viper
Phoenix
Saw rears on ebay for $250 each today. It's that warehouse place that only carries a few sets at a time.
Hisserman
Waterford, MI
There's one guy that has rears on eBay for $184, but it goes off early this evening. Sorry, I don't have time to hook you up with a link right now.
joe117
Maryland, USA
Low pressure probably did it but I don't think 26psi would do it.
I think you must have run over something and caused a further loss of pressure that you didn't notice.
Get the cheap sticky Kouhmos if you can use 17".
Craig 201 MPH
Toronto Ontario, Canada
Cheap solution. Just do a walk around and spare the 3 minutes while the car idles up to operating temp before a drive.
even comes in neato colors.
3snakes
i have 18inch. got tires at my speed shop 12.00 per tire more . but that inculds mount an bal. i had check tire pres. three days before. this was after driving car for 2nrs it went flat.
ATLVPR
