Grease a slow moving bit and tape/cover off your work area! If you can't remove it there, the cam may have to come out?
Isn't the 708 the same as the Comp Coupe cam?
The cam has been fitted with the three bolt holes for the adjust. timing chain. The instructions says (300 in. lbs) 25 ft. lbs. I took the cam to a machine shop this morning (this is a custon grind cam) and we both noticed that the supplied bolts seem to be a tab to long and would explain why the Cam timing chain sprocket was loose after torquing the bolts to 25 ft. lbs.
I purchased grade 8 bolts from a auto store yesterday night that were 5/16-18 x 1 1/4 and those seemed to a slightly to long as well but not as long as the bolts supplied with the timing chain.
I've never had something like this happen to me and be anything other than a tedious nightmare.
Alternative to wasted time and extreme frustration?
Order a new cam. Next Day UPS it.![]()
The bolt holes were 1 inch but bolts were binding when torqued down. The supplied bolts were at least 1 1/2.
I have the Cam back in now.
Ran into a new problem, while torquing the bolts down on the Cam thrust plate and then trying to remove it, damn bolt broke. Thank god it was easy to get out with pilers as some of the thread was sticking out. I removed the second bolt and noticed that it had chips in it. I could see the middle of the bolt. I assume once these bolts come out, they need to be replaced as all the miles with constant stress from pulling and spining parts takes it tolls on them. So for those non pros attempting this, throw away the stock bolts and replace with new ones.
Hopefully I will have no issues with the heads or intake.
agreed... if you now have a broken screw extractor in there, its game over... That material is IMPOSSIBLE to drill into.. even if you do manage to get the bolt out. It will always be in the back of your mind, weather its holding or not (at least it would mine)..
Order a new cam, and be done with it..
Hmm, the supplied bolts should have been 1.25"...? It is certainly possible they came out of the next bin over by accident.
I am very surprised at the issues you are having with snapping bolts? Are you sure your torque wrench is accurate and you are using the right settings? Those bolts are not under that much stress really.
Camfab, thanks for the advise, keeping preaching, good info. here.
I have the heads on and used the original head bolts as I was told I could. Cam was degreed per instructions I received with adjustable timing chain, crank has been cycled twice to make sure Cam/crank sprocets match up. I had plan on putting pushrobs, rocker on after I put timing chain cover on as I am going by the service manual. I vac'ed the pistons, top of engine and cylinder head mounting surface and q-tipped the cylinder head bolt holes (noticed some oil in there, I believe from removal). I have new springs (crowers) and push robs along with T & D RRs.
I had planned on putting the thermostat and intake on then leave the timing chain cover as the last thing I do.
Also to answer the first part of your comment, the long bolts were test fitted and after I noticed something was wrong with the CAM/sprocket/bolts, I tried to remove them and snap. I am not rushing, really taking my time with this and reading/re/re/re reading everything and calling Chuck probably more then he would like.
I was going to replace the crank seal after I got the timing cover on as I've heard its easier this way.
Spring bind was checked.
But again thanks for the advise and easy went out the window 2 weeks ago.
