BRAKE COOLING
KWIK
PORTLAND OR
GO TO TIMBERLINE DODGE .COM & CLICK ON K A X WE HAVE COOLING KITS THAT WORK
KEN
Tom F&L GoR
Wappingers Falls
Any pictures of an installation available?
Pegasus Auto Racing Supplies sells ducts NACA ducts for $20 and 6' lengths of 3" silicone hose for $52. I tried this idea and had a single plate to mount the ducts basically under the radiator. The problem I had was that with only zip ties to hold the end "near" the caliper, the ties became "pressure" points and after a few weeks the hose end had whipped itself to shreds. Plus there isn't as much room as you think in between sway bar ends links, steering arms, and the like. What I thought was really needed was a fabricated piece that mounted on the upright, supported and accepted the 3" hose, and directed the air to the rotor. I'd buy one of those...
Pegasus
