Clutch Lowering Kit
puma
Quebec
exactly, seat lowering cured my problem of the knee hitting the lower portion of the dash. I don't have my viper anymore but still have the seat lowering kit, let me know if you want to buy it.
R
Rheeder218
Harrison Twp MI
i put gen 3 seats in so the lowering kit wont work. different seat track compared to gen 1 and gen 2 tracks. Its not that bad with the knee hitting the light switch but every little bit helps. thanks for the offer
Dave149
Ontario, Canada
I just put the Roe kit in my gen II, and I found the pedal assembly was loose! The bolt that was loose is accessed behind the PCM on the left side (under the hood) of the foot well. The entire clutch master was moving quite a bit when the clutch pedal was pushed. Not sure if the gen I is bolted in the same but it's something to look at if you do the mod.
BarryLB
