Coil Packs
GTS Bruce
Orchard Park,NY,USA
I thought someone would know this off the top of their heads and replied by now.Well I looked it up in my 01 service manual.Temp 70-80deg.Primary 0.52 to 0.63 Ohms.Secondary 11,600 to 15,800 Ohms.Are you checking yours or maybe building a better coil pack?Doesn't list the exact output but supposed to be around 40,000 volts. Bruce
kverges
Dallas, TX USA
Static resistance is only part of the equation; although I suspect it is not spec'd, the ratio of primary/secondary turns on the coils will give an indication of the voltage step-up. Also, the inductance may be significant, too and would be interesting to know.
Let us know what coils you find that are compatible and any performance improvement you note (esp in secondary voltage and spark energy).
BarryLB
