I have had some cooling issues recently, radiator drained, flushed and cleaned in an attempt to rememdy. I burped and burped until I got very little if any bubbles. Today started very cool, around 180ish and never got past the center mark on the gauge. This afternoon the air temp was around 100 so it wasn’t cool by any measurements. While I was on the HWY I never got above 195 on the gauge. Pulled in and parked and when I got back in the car I noticed the Roe fan controller hadn’t kicked the fan on. I assumed it was under the required temp until I started the car.
I sat idle watching the gauge and it steadily crept to 225 and then to 250. I got out of the car and noticed the fan wasn’t on. Turned the car off and waited for the fan, nothing. Fired the car back up and let it idle some more, no fan. After letting it cool down a little I got back on the HWY and drove home, temps back to normal. When I got home the fan cycled and did its normal thing. Seems like I may have an issue with the fan not kicking on as it should. I would assume they either work or don’t work, doesn’t seems as if there would be a medium if it were a bad fan?
Trying to narrow down the problems prior to tearing into the T-stat. I dont mind doing it but would rather not if I can avoid it.
Thanks,
Thanks,
