Trailertrash
I need to no if the 708 cam that was installed in the 96 to 99 GTS using the same stock valve springs as the later model GTS 2000 to 2002? Do you know what the spring pressure was at installed height on the 96-99 gen2 I would like to remove the cream puf cam from my 2000 GTS and install the 708 grind from the 96-99 GTS slight performance gain but the overlap differance provides a much better sound quality that I like.
