Differential fluid/drain plug question.
AviP
New Canaan, CT
I was going to change the differential fluid and was wondering which one to use?
Mopar 75W140 + 4oz friction modifier, or
Mobil 1 75W190 (includes friction modifier), or
Royal Purple 75W140 (includes friction modifier)
What do most DIYers do? I did a search but couldn't find anything conclusive.
Also, can someone please pdf and email me (ntmd8r at yahoo dot com) the procedure for adding a drain plug to the differential.
Regards,
-Avi
1997 Viper GTS
Well, realizing that our Vipers see street use...I stick with the Mopar fluids for the differential...noting that I have seen many track cars use the same without any problems.
I would suggest that you follow the link below, join the VCA, and you will find Jerry Scott's procedure for adding a drain plug in the Illustrated Upgrades section:
https://www.viperclub.org/join/
dave6666
Nothing wrong with the factory fill fluids if you have factory internals. The engineers that design cars are generally not stupid that way.
You can **** the fluid out using a Mityvac or equiv and pump it back in using the same.
