Difficult hot starting
GTSnake
Motor City
When my car is cold it starts up immediately. However when it's warm it takes a long time to start. After 3-5 seconds of cranking I let go the key and it barely sputters to life. I've changed the MAP sensor, AIS motor and cleaned the air filters. Does anyone have any ideas?
charlesj
Bethlehem, PA
just reviewed history on my car. prev owner had these issues... (sorry about caps...)
INSPECT STARTING SYSTEM - 8 SEC TO START & JUST TURNS & WHEN DOES START, FEELS LIKE CHOKING - DIAGNOSED & REPLACED FUEL PUMP & HYDRAULIC CLUTCH ASSEMBLY & GASKET INTAKE MANIFOLD
here's another issue...
INSPECT STARTING SYSTEM - CUSTOMER STATES INTERMITTANT NO CRANKING, MAY BE RELATED TO ALARM, REPLACED NEUTRAL SAFETY SWITCH; INSPECT ELECTRICAL SYSTEM - TRACE & REPAIR LOOSE CONNECTOR IN BK 212 CIR RELAY
and another...
INSPECT FUEL SYSTEM - CUSTOMER STATES ENGINE SPINS 5-7 SECONDS BEFORE STARTING - ORDER FUEL PUMP
yup, you read right. fuel pump was replaced twice... once at 1,200 miles and again at 16,500 miles.
and jerry got to the car at 26,000 miles...
DIAGNOSE ELECTRICAL SYSTEM - RODENTS ATE WIRING
REPLACE SPEED SENSOR - FUEL SYSTEM - CUSTOMER STATES ENGINE SPINS 5-7 SECONDS BEFORE STARTING - ORDER FUEL PUMP
DIAGNOSE CHECK ENGINE LT - NO SPEEDO SIGNAL, SPECIAL ORDERED
that's right, 3rd fuel pump. no problems evident since. hope this info helps...
GTSnake
GTSnake
Motor City
If it cools off (say 24 hours) it starts better than when hot (1 hour)?
Exactly. It only happens when it's hot. If I let it cool overnight it starts right up. I'm thinking it's got to be electrical somehow.
BTW I'm planning on upgrading the fuel system anyway so I hope it IS the fuel pump.
zeeshan_k24
