does the fan module on 03 to 06 go bad and can they be rebuilt
Morristown,NJ
I was concerned about the fan module on my 06 can they be rebuilt or what to do if it goes bad there are so many parts on the car that concern me I am being a bit more careful about driving it now, kind of takes the fun out of it. Whats the scoop on parts for the future like body panels even the headlight modules ???
There is an initiative on the forum that's working on repro parts and venders. Probably a little ways out, but the future of these cars is in the works. Until repro OEM parts become the norm, your options are pay for what's available, find places that rebuild/fix components, or do like any resto mod car and find an aftermarket solution. Looking at the glass as half full, these cars are far too nostalgic and loved to ever go away.
Depends on what you mean by "go bad". They are hydraulic motors with some valving in them. Generally speaking I wouldn't expect the motors to go bad unless something else in the system goes bad first (aka you shred a pump and put a bunch of metal into the system. What I also learned is that the steering relief valve is built into the pump, and I had the bad luck of having my valve stick open. I tried taking out the shuttle and cleaning it up, but it just stuck again.
So long story short, yes, they can go bad, though I think actually using them will probably keep them alive longer than just letting them sit. I'd be more worried about a valve gumming up or getting corrosion on it from sitting around in one spot than having constant fluid flow. Ultimately they are just a casting that's full of parts, so unless the casting itself gets really beat up or corroded, I would bet someone out there could probably reman the guts. Hard to say how much that might cost as it might take a machine shop making a one-off piece to fix it, but my point of view has always been "someone made this part before, so someone can make it again if needed".
Yeah, Mercedes was big on the hydraulic fan thing as well. I don't know if any of their stuff would have crossed over, but it was of the same era when they owned Chrysler.
Cape Coral, FL
Jeep Grand Cherokee of the same era is supposed to have the same hydraulic fan module.
Close, but no. Control and valving differs.
Internal parts theoretically could be swapped, but these units are very difficult to R&R as the internal clearances are insanely tight. They want to jam so easily its a joke... they are assembled with fixtures in manufacturing.
All that said, its virtually never the motor that goes bad, unless a pump went bad and spewed metal into the system. Its nearly always the fan blade taking a rock hit, and cracking... then damaging the shroud.
I do have future plans to address some of these issues, with module repairs, and rebuildable lines and fittings, filter kits, replacement blades... but thats still a long way out.
I always say,
Best bet is to go electric......................................
So seriously, why doesn't my G4 have cooling issues? Bigger hotter engine, pretty much the same radiator, electric fans.
Cape Coral, FL
Come down here to FL in July! You will live at 215 anywhere but the highway.
Its a well known fact that G4 & 5 cars have a harder time staying cool this far south than G3 cars... and god help you in a G1/2 car over summer here during the day.
Simple matter of flow numbers dont lie.
I am in south AL, so....... yes I know. My G4 has had no issues ever. Rock solid at 195.
distorto
