Engine Check Light Problem Tracked Down
SUN RA KAT
Guest
My Equus 3100 Code Reader says I have a P0208 - Injector #8 output driver stage does not respond correctly to the control signal.
My Viper Tech and I will be installing the MSD Boost Retard box tomorrow and also will hopefully fix Injector #8.
ACR Larry
RPV CA USA
Kenny,
I had the same problem with injector #7. Sean told me a few others experienced injector issues with the new setup. A little contact cleaner and it was as good as new.
Larry
Sean Roe
Jacksonville, FL
Chrysler's injector plugs are the only ones I know of that don't have a retaining clip on them. The slot is there, but the metal clip is not. Certainly doesn't help matters when you just installed 10 new injectors.
Sean
Vipermed 97.01
Tampa Fl. USA
gen1 has them i ordered gen1 clips for both of my gen2s they fit its not really needed with factory manifolds but with Seans setup its good assurance as you no longer have viewable access
