slitherv10
- Joined
- Jan 23, 2012
- Posts
- 517
- Reaction score
- 0
Hi everyone,
I have a 1996 GTS and just took out the viper for its 4th ride this year after a 4 month storage. I noticed when i would be warming it up especialy, that it had a slight miss in the engine. As I started to drive it, it would slowly go away but occasionaly I would feel the missing. On the last ride i noticed big time hesitations on start up and during the ride, and lots of backfiring. I noticed that the drivers side of the motor was not as hot as the passengers side around the heads and the headers. I felt all the ignition wires and noticed that one of the wires ( drivers side closest to the driver) was cold. The others on the same side got hotter as you moved toward the front of the car. The passengers side ignition wires were very hot and so was teh heads and headers. From the rear exhaust you could feel the drivers side pipe had cooler exhaust than the passenger side exhaust fumes which were much hotter.
What do you think may be the problem and how can I fix this ?
could be hung injector from sitting, and leanpoping
