Forced Induction Vipers, Anyone using Water Injection?
Joel
Ireland
I designed and patented a water injection system for use on supercharged <u>intercooled</u> engines about 10 years ago. It worked great on my test vehicle at 20psi boost. If you're interested get in touch
Russ M
LA, California
Water injection is not a fix, its what you do if funds dont allow you to do the correct cure.
What you should be doing is trying to solve the reason you need water to slow down your combustion rate, and decrease your horse power. Install an intercooler/fuel and ignition management unit/fuel pump/whatever but water does not belong in your combustion chamber.
duostunsail
