01ACR/VIPER
Will a 295/35/18 fit our fronts?i found a pretty good deal on a set.thanks,dennis
Hi Dennis,
They will fit, will be marginally taller (diameter 26.1" vs. 25.6" stock), have less revolutions per miles, 795 vs. 814 stock.
My recommendation would be to go for 11" front rim width if you can find them in a matching brand and design.
The 10" stock rim will work, but the 295 tire size is truly the maximum width you should consider installing on the stock rims.
Hope this helps,
Phil
i was wondering more about the clearance more than anything else.no rubbing probs when turning?![]()
