FRONT TIRES
01ACR/VIPER
01ACR/VIPER
ORLANDO
thats just on the rears....i need info on fronts.i think someone on here said they are using 295 on the fronts?:dunno:
Vypr Phil
SoCal
Will a 295/35/18 fit our fronts?i found a pretty good deal on a set.thanks,dennis
Hi Dennis,
They will fit, will be marginally taller (diameter 26.1" vs. 25.6" stock), have less revolutions per miles, 795 vs. 814 stock.
My recommendation would be to go for 11" front rim width if you can find them in a matching brand and design.
The 10" stock rim will work, but the 295 tire size is truly the maximum width you should consider installing on the stock rims.
Hope this helps,
Phil
01ACR/VIPER
01ACR/VIPER
ORLANDO
Hi Dennis,
Hope this helps,
Phil
thanks phil,i found a great deal on a set of pilot sports one.as we all know,they are high priced to death.i will now look into the purchase of them.:headbang:i was wondering more about the clearance more than anything else.
Vypr Phil
SoCal
Dennis,
I know some folks who run 305's and even 315's fronts without problems.
Phil
Catwood
no rubbing probs when turning?:dunno:
I also run 1/2 spacers. I get a little rub with my track rims that are an inch wider in hard high speed corners. Just a touch to the upper inner fender lip.
I've run as big as 335 with no spacers on the wider rims but rubbed a little at full lock
Car didn't push though ;)
zeeshan_k24
