gen 2 stock intake design question....
drlee50
Can anyone tell me how its designed exactly on the inside? What I assume is that one throttle body feeds 5 opposite bank cylinders and the other TB feeds the other 5. My main concern is: is there any passageway between the two sides? Is there a balance tube/ passage or something that connects all 10 cylinders to each TB or are they totally separate?
thanks!
Tom86ZT
chicago, IL
Lee,
Vaguely remember them being completely seperate runners (as you described). Someone had a pic way back when of a intake mani cut right down the middle.
Quick test would be to block one end of runners, fill those runner with a fluid through their throttle body, and see if it goes into oposing runners.
Wait there is a balance tube....but may not be what you need for a TT setup. Balance tube would be better before TB I'd think in this case.
Tom
D
drlee50
I am going to pull the intake off for the cam swap anyway so I am just going to test it as you described....but Ill just use compressed air I think. The turbos and UGR kit arrived yesterday!
SKY1960
