Help, It's clutch time. What is the best set-up for high HP cars
SNKBYT
E.SWANZEY, NH
Help, It\'s clutch time. What is the best set-up for high HP cars
I'm ready to replace the clutch,plate,and flywheel. What is the best set-up for high HP cars. I do some drag racing. Thanks Tim
SNKBYT
E.SWANZEY, NH
Re: Help, It\'s clutch time. What is the best set-up for high HP cars
Who sells McCloud? How much HP do you have? Are these better than centerforce?
txlen
NORTH STAR DODGE VIPER TECH, S.A. TX
i would suggest the mcleod dual disc setup or the centerforce unit works good too..jus remove half the weights off it and it shifts fine......give me a yell if ya need some help on it...Len
VIPER D
dutchess county, ny
Just did a rps clutch and flywheel go till 1000 tq
go to turboclutch.com
SNKBYT
E.SWANZEY, NH
ViperD Which clutch package did you use. Did you use the RPS flywheel too?
Joseph Dell
Atlanta, GA 30338
I too have an RPS and it has held up quite well with over 60 passes on it so far.
Some folks had issue with RPS earlier on (and their 1st clutch stunk), but this clutch is doing extremely well.
JD
VIPER D
dutchess county, ny
RPS MAX 6PUCK SERIES AND THE LIGHT FLYWHEEL
VD..
SNKBYT
E.SWANZEY, NH
Is any one using the CYN-R-G Flywheel from RPS with a Centerforce clutch? How does this setup/combination sound?
Tommy K
Tampa, FL
I'm running what Brian is running. Installed by UGR. It is very streetable! After multiple 9 second passes, they're still going strong. Not to grabby and no chatter either. Not much different than stock really. Call Kevin and he'll hook you up.
Tom
Joseph Dell
Atlanta, GA 30338
Sorry I missed the post before!
The clutch feels like a stock clutch on the street. It hooks hard off the line and is extremely drivable. In fact, if I hadn't installed it myself, i'd think it was a stock clutch.
JD
Cudaman
USA
I have been running a stock clutch...since day 1.
Cudaman :usa:
Shelby3
liu;g
Cudaman :usa:
:shocked: :shocked: :shocked:
The SAME stock clutch? :usa:
Cudaman
USA
Cudaman :usa:
AAAAh....No....25,000 miles on the Viper.
Original clutch burned up learning to launch on ET Streets.
Next one I took out on practicing shifts on the highway....oooooops ...downshift instead of next higher gear....took out clutch and transmission, that was a VERY expensive shift!
The clutch that is in now has had MANY dyno's and MANY passes down the track...nothing is forever.
But I should have said SAME type of clutch since day one.
Cudaman :usa:
Shelby3
liu;g
Still impressive. :2tu: :usa:
Joseph Dell
Atlanta, GA 30338
I wonder what other people are using for clutches in their stroker motors...
BarryLB
