Simms
I've have them sitting in my garage for months now and I finally did a coolant flush today (Thanks again to the Wizard for his tips
). Before I went to install the upper hose, I started playing with the valve. It WOULD NOT turn at all by hand but appreared to be open. Or it was atleast screwed out. Not sure how the valve works, I tried to twist it in to close it before I installed it. I literaly had to put a wrench on the piece syliconed into the hose and twist the valve screw with a pair of plyers. It started to twist in ok. However, I notice when looking into the hose, the valve was moving inward. I wasn't actually twisting the little threaded bolt (for lack of better words), the whole valve piece was moving. So when the valve was closed and flush on the outside of the hose, the middle part of the valve was sticking out into the center of the hose inside. It apprears the vavle is three pieces, the screw, a center piece the screw threads into, and an outer piece that is syliconed into the hose. It didn't seem right that the center piece would stick out inside the hose so I decide to hold that piece inside the hose and twist the screw somemore. Anyway, I BROKE THE FRICKIN SCREW RIGHT OFF. My question is how does this valve work? Was mine correct before I broke it, or did I break it because it wasn't moving properly? (please ignore my spelling and terrible explainations, I'm in a rush)
