When it hangs at 2,500, get your foot under the gas pedal and raise it up. If the hang goes away, some adjustment to the return springs, or alignment of the two throttle bodies needs to be made (loosen the bolts and you can rotate them slightly).
If it doesn't go away when you raise the pedal, check the passenger side adjustment screw on the throttle linkage and make sure it's not holding the TB partially open.
The last item to check would be the stop screws on the TB's, but I doubt that's it.
Regards,
Sean
