Ignition wires to which coil connection?
94RT10Ohio
Northwood, Ohio
I am putting a SC on my 04 SRT Ram. I documented the wires as I took them off but wanted a confirmation from someone with a service manual.
Rear of engine
2 4 6
3 7 1
5 9
10 8
Thanks!
fqberful
Central FL
Rear of engine
2 4 6
3 7 1
5 9
10 8
Thanks!
Hi,
The 04 Ram & SRT FSM on page 8I-21 says "Take care to match cylinder number on ignition coil with cylinder number on ignition cables" ... There's no pictures I can find that show the physical location but the implication is the coils are marked -- so you should be able to match the wires back. The groupings of your numbers match the other verbiage in the text.
However, the 06 Viper FSM has a pic : See the attachment
HTH
--Ed
94RT10Ohio
Northwood, Ohio
Thanks!! That is what I had but wanted to make sure. Would have been bad to get the SC on there and have the wires wrong and have to take it back apart!
Roadrunner
The cylinder numbers should be showing as they are molded into the coil packs themselves at the base of each tower.
BarryLB
