Individual Foot Pedal adjustment on RT10
Con
Does anyone know how to individually adjust the height of the foot pedals on an RT10?
I think the summary on that is basically you remove the adjust cable from the pedals you don't want to move, then use the adjuster to move the ones that are still connected. I did the same thing with my gen 3 (electronically done, but same principle). I moved the gas and brake all the way back for comfortable cruising (long legs), but moved the clutch forward since it has quite a bit of throw and I was having to straight leg it to get the pedal all the way down. Moved it up so my knee still has a slight bend with the clutch fully engaged.
Tom F&L GoR
Wappingers Falls
I did exactly this, made a permanent aluminum handle for clutch cable alone (jewelers square file hole to slip on end of cable) and left it accessible through fuse panel access.
C
Con
Thanks for the brilliant feedback
You guys are awesome!!!!!!!
