wastntim
Anybody add a lightweight flywheel and not like it?
I'd look into the chromoly flywheel from DC Performance. DC Performance: Proven Performance
OK. 10 pounds lighter than stock. How does that compare to the Fidanza weight wise?
i have the fidanza and love it, with new stock clutch. Drives like stock but does not like riding slow throught a parking like (I have a custon grind custom=lumpy) but does not happen often and when it does, just push the clutch in.
Its way easier to downshift rev match, I mean alot. I read an article some time ago where a z06 was outfitted with an aftermarket lightweight flywheel and clutch and the car accelrated quicker to 70 100 and 150 (2 seconds) but hp remained the same. I;ll post if i can find link.
All in all I love my lightweight wheel.
I've heard some have a problem with clutch grip after some hard track miles. I haven't tried it myself. I'm still stock.
I think Fidanza is lighter. I'm not certain if lighter is always better but I was hoping Dan from DC Performance would chime in.
Don't forget that it will improve rear wheel braking. With the engine speed high, clutch engaged and heavy on the brakes, the rear calipers also have to slow down the drivetrain. Less flywheel means greater energy extracted to slow the vehicle rather than drivetrain.
I have over 50K miles on my Fidanza, including 500 track miles and at least a dozen xcrosses. Zero issues. I think 17 or 17.5 pounds is the Fidanza weight. I have always thought the Viper to be the easiest clutch car I've ever owned and that includes the flywheel addition. For a test, I have actually started off in 4th gear with the light flywheel. It wasn't hard to do. I have started many xcrosses in 2nd and smoked the tires as much or as little as I want. Very little extra revs required. I consider the flywheel mod a very good one.
No Viper....light flywheel or not....likes riding through a parking lot. You always have to be putting the clutch in once in a while.....especially when cold.
Steve
If you want to BEAT on it, go Chromoly Steel (and save significant $$$) and only give up about 2 lbs....Vs the 42 OE it means little.
Save how much? DCPerformance has their chromoly listed at $399 and states that it is 10lbs lighter than the 42lb(?) stock flywheel. But the Fidanza is 17.5lbs?
We've got some contradicting information going on. I've got a stock flywheel I can weigh. If somebody sends me a chromoly and a Fidanza I'll weight them all and get it straight.
Not sure which ones I'll return though.![]()
too.Save how much? DCPerformance has their chromoly listed at $399 and states that it is 10lbs lighter than the 42lb(?) stock flywheel. But the Fidanza is 17.5lbs?
