wellis77
- Joined
- Aug 7, 2009
- Posts
- 31
- Reaction score
- 0
I mentioned in a previous thread that I'm not a Viper owner, but am building a Viper themed Dodge Dart, from the ground up. I'm planning a full chassis for the car and was originally building the car off an Art Morrison chassis using C6 front suspension and a 3 link rear. I've since begun purchasing parts to build an IRS using a Gen 3 Viper rear and am investigating the possibility of adapting the entire Gen 3 front and rear suspension. If the measurements work out it would save me a lot of time and effort from building my own control arms and laying out the geometry. The problem is I don't have access to a Gen 3 Viper to get measurements so I'm hoping someone on this board would be willing to help. What I need is listed below:
-distance from front wheel flange (rotor flange) to upper control arm mount as well as the lower control arm mount
-same for the rear wheel
-if possible I'd also like to know the front to back angle of the upper & lower control arms and side to side angles of the control arms from the knuckle to respective mounts at ride height
-the last measurement I believe I would need is mounting hole to mounting hole distance for coil-over shocks (front and rear) at ride height
-pics would help too if possible
This will help me determine the width of my frame rails and plot out my suspension points. Track width isn't going to be a problem, I'm about 2.75" wider in front and .1" wider in the rear. The main thing is determining the rail width and getting the geometry the same as the Viper. I know this is asking a lot but any help you can provide is greatly appreciated OR, if there are any Gen 3 owners in the Grand Rapids, MI area (West MI) that wouldn't mind me coming by to take some measurements that would be great too.
Thanks a bunch. Will
on public roads
