viperdude118
Well, I decided that I was going to install poly mounts into the viper this weekend. I gave up for today as I ran out of sunlight. I must say that this job is much more challenging then I expected, so much so that I'd rather eat glass then do this job again.
It seems simple, loosen some bolts raise the engine, take out the bolts, take out the mounts, switch to new ones, put back into the car, lower engine and tighten everything down.
Well the first problem I ran into was removing the lag bolts holding the bracket to the engine block, I have the stock exhaust manifolds and there isn't enough clearance for the upper bolts to come out, they hit the collector.
There really isn't room to get anything in there, I managed to get the dremel in there to hack off about half of each bolt, then bend them to get them out. I really didn't want to have to loosen the manifolds unless I absolutely had too.
Now that I have everything out and switched, I am trying to get the new ones in, and get all the bolt holes to line back up. It isn't working though, I followed the steps in the illustrated write-ups done by ViperTony, however everything is not lining up, so I can't get two of the lag bolts to go back in. I've had the motor up and down about a dozen times now.......
I'll give it another shot tomorrow, anyone have any tricks to share?
