My car won't start.....
C
costanZo
Haverhill, MA
It says that it is 1 1/4 amp. This one works in three stages. I remember when I bought my ACR it took the thing about a day to get the battery up to a full charge.
hmm.. yea i saw that it listed 1 1/4 amp too, but wasn't sure if it had higher then that and was just not listed. I guess the one I have with the feature of changing the tender to charge at 2 or 4amps is better. Still, the whole day is quite awhile if you're looking to drive it that very moment as you could with jump starting it. :(
C
costanZo
Haverhill, MA
nobody ever listens to me... :)
Well I will definitely take your advice next time ;)
Besides, even if I did do that. I still would've had to have my car towed lol. Unless I had someone who let me use their PCM leave it in my car so I could drive my car with their PCM to a shop to have a new one put in haha.
Regardless, at the time I figured the best solution was to tow the car to someone who I knew would fix it so I wouldn't have to deal with anymore problems and Steve Heitz did just that. :2tu:
kcobean
Sterling, VA
If you can work some simple tools, you can change the PCM out yourself. It's easily accessible, and just a couple of bolts (or screws?) and I think two connectors.
C
costanZo
Haverhill, MA
I managed to take the panel off myself with my father; however, we weren't completely sure at the time if it was in fact the PCM. So I felt it was the best decision to have the car shipped to a Viper Technician who could diagnose the problem and then replace the part as needed. Your method would have been the easiest though haha, but I didn't want to buy the part myself and try to install it, because if the PCM wasn't the issue then I would have had to try and sell it and still figure out what the real problem was.
Jack B
NE Ohio
It has three large connectors and is below the fuse box at the drivers kickbox.
C
costanZo
Haverhill, MA
Hey Jack, yes my father and I saw that. We unplugged all three at one point. There was a black, gray and white plug, but if I remember correctly when using the test light to check the fuses, the black plug was the only one that mattered to check.
merlu
