Need New Radio/CD Player Advice
MR VENOM
Newbury Park, CA, USA
What would be the easiest to install without modifications. I'm happy with the sound of my existing speakers, so I won't be replacing them. Mainly interested in the CD player (doesn't have to be multiple disc) since my 95 R/T did not come with one. Just looking for a quality unit with about the same output.
RoadKing
San Antonio, TX USofA
I've got the stock Alpine from a 2000 RT/10 if you're interested. I upgraded the whole system, and have it left over. Should drop in no problem. Drop me an email and I'll make you a good deal.
SapphireGTS
Columbus Ohio
There is a CDA and a CDM from alpine. One has a black connector while the other is a white. They are not interchangeable (although they look it) If you get an aftermarket Alpine make sure you take out your OEM head unit to see which connector you have. If you get the right one it will hook right it. (at least on the newer Vipers)
I have my factory set up if you want it.
[email protected]
prodiver
Apache Junction AZ
I have a 95 that I removed and replaced with a Clarion Auto PC with a built in navigation system. I still have the one I removed. Let me know if you want it.
Mando9595
