AAKVIPER
Ordered a new drain plug and gasket for my Gen 1 from my Dodge dealer..Looks different socket head size but it should fit. It now has a compression type of O ring. The older compo had the rubber O ring kind of pressed on to the drain plug other lip. Not sure if the Gen 3 is different..But Gen 1 and 2 should work with these new numbers.
The new numbers are..1-04763739 drain plug and O ring gasket number is 1-04763738..I hope this helps out other members. Approximately $40.00.
Arthur
Arthur
