NOS anyone?
anton28
Is any-one here running a NOS system if so which one? What is best recomended for a stock 99gts.
TOOOFST
Barrington,il
I think NX has the best all around deal.
Prior nitrous install experience recommended
and dyno before trying yourself.Use 1 step colder plugs.
Autolite's 3924 work well.
If you want a pimped system buy my TOOFAST bracket and
have the lines shortened.Takes a day to put together
but when finished can be on/off your car in minutes.
Average install with dyno time runs $2000.
A
anton28
What is this TOOFAST bracket that your talking about. Do you have pics?
A
anton28
Which one do you guys think is best NOS, TNT, NX and what is the propane all about. Do i need it?
plumcrazy
ALL OVER
NX if ya ask me. the BTR propane is also a nice setup and makes a lot of power.
make sure to get up on a dyno and have it tuned before you use it.
RedEnuf93
Lancaster, PA
NX, definately.
I've had it several years, works well and my Gen 1 has taken anything from 100shot to 300 shot.
With big it shoots like a bullet...
Even with my supercharger, I'm planning to keep the NX.
A
anton28
i ran NOS on my 95formula for about 2 years and i never got it dino tuned. Is there a reason i need to dino tune the viper.
plumcrazy
ALL OVER
cause you dont know what the A/F is and it can blow the motor and the motor in the viper is a lot more expensive than a 95 formula's.
it just isnt smart to drive it with the nitrous without knowing what the engine is doing or needing.
but its YOUR car not mine.
a dyno session is gonna run you about $200-250 by the way.
IEATVETS
Cottage Grove, Wis.
Nitrous or not, you ALWAYS dyno tune the car after you install a power adder. If your motor is running lean and you engage the nitrous, you will soon find out just how pricey these motors really are! Propane is the extra "fuel" needed when on the juice. If you have a NX kit, you get the needed fuel through a solenoid which is hooked up to the schraeder valve.
A
anton28
do you guys know anyone in northern california for tuning?
TOOOFST
Barrington,il
Pictured in my avatar,maybe someone here can post a pic.
Jack?
Its a simple aluminum plate welded to tubes that slide over your smooth tubes.You mount the solinoids and fogger nozzles.keeps everything straight tight and shortens the lines.I've got a custom system thats adjustable up to 700RW ready to bolt on $750.It has 4 NOS foggler nozzles.
$150 no finish
$200 brush
$250 mirror
A
anton28
I wish i could see the pics. What Brand is the kit? Is it new Used? What size bottle?
A
anton28
im looking in to toofst system myself, How is it compared to the NX set up?
BarryLB
