NX setup
term
What do I need to setup a NX kit on my 97 Viper?
I have a guy who has a brand new single nozzle NX wet ket and some extra parts (Extra nozzle) that he says should work to make the kit work with the twin throttle body setup of the viper.
I can get the whole setup with a bottle warmer, blowdown, purge for about 300..
PBJ
St. Louis, Missouri USA
You should only need 2 y fittings and the 2 additional # 3 lines for the second nozzle. I would pick up a NX wot switch, some 200 shot jets, and be ready to pick up some major torque.
Later,
Joe
GTSnake
Motor City
Wouldn't you also need some type of hard tube to replace the silicone ones to mount the nozzles?
Snakester
Morgan Hill
Also I think that it's best to get a MSD window switch, and send it off to MSD and have it modded for the Viper. The whole cost including the modification (for 2 cyl engine) is less than $100, and it beats the heck out of a manual trigger. $300 is a killer price.
Adding the Y-splitters, extra air and fuel lines, jets and window switch should be about $150 total. Which is still about 1/3rd the price of a new NX N2O Viper kit.
I personally didn't have any problem mounting the shark nozzles in the silicone tubes. I just used wide washer/fittings to mount the nozzles firmly in the tubes.
-Dean.
TOOOFST
Barrington,il
www.racetested.com
check Deny out before you purchase.
Nitrous is already cheap HP.This set up guarantees everything with cash back.This set up has the ONLY automatic pulsed solinoid.If you use a progressive computer,this solinoid is all you need.Use anyone else and they recommend 2 inline.This set up has the fastest install/removal jets,since there's only 2.
Good call going nitrous.You get the fun of stock, and a 10sec monster to scare the kids.
Mando9595
