Odometer and gear change
TorQ Junkie
central, il
While cruising at the Midwest Rendezvous, I noticed that the mileage on my odometer was way off compared to that indicated on the map (more miles passed by).
I have 3:55's and the black box to calibrate the speedo, but does this also adjust the odometer? Is the odometer reading mechanical in contrast to the speedo's being electronic?
KenH
Portland, OR, USA
I have 3.55's with the unitrax speedo cal box and I went on a 125 mile or so car run with mileage markers last weekend and my odometer stayed accurate within a few 10's over the course, so I think the box cals both the speedometer and the odometer. Hadn't even thought about it until you brought it up though.
00prowler
Vernon CT USA
There are dip switches inside that are adjustable..they may not be set for your gearset...Is your speed correct?AL...
zeeshan_k24
