Venom 1000TT
I drive the car & when I get into boost to activate blow off valves I have oil blowing on the engine from them??? Anyone have any ideas? I thought only air was supposed to be going thru them?
If you mean white smoke, none at all. Blows black smoke when I get on it. No check valve. Oil feed line to where?yes probably turbo seals, I dont think he has scavenge pumps. If so that is easay enought to check. I little oil fim is ok, but if you actually have oil pumping out that is not good. You should not run the car eather as oil in the intake will promote detination. You will now need to clean out your innercooler and tubing also. Do you have a check valve in the oil feed line? Too much oil pressure will blow past the turbo seals. Does the car smoke?
I agrre on theory-but did you ever own a turbo car? A little oil is norma, you are correct if you can see oil buring then you have problems, no such thing as white smoke for a headgasket-it would be white steam and smell very sweet. Smoke is from buring and will only be oil or gas.White smoke = head gasket/water/coolant
Blueish Smoke = Oil (piston ring usually)
Black = Fuel/Rich tune (normal for turbo cars)
If there is enough oil that you are noticing it on the engine, It should be an area of concern. If it is enough to be coming out of your BOV, it is enough to be getting into the intake manifold. That can cause a lot of damage and will drasticly effect performance.
I forgot to mention, the oil's only coming out of one BOV. The driver's side. So maybe tomorrow I'll take off the hose from the turbo and intercooler hose to check for oil. Maybe it's just the driver turbo seal gone? Thanks for all the input though!
Well, I took off the hoses/pipes on the driver side from the turbo to the intercooler. No oil! Duh!! I forgot that the passenger side turbo feeds the driver side intake & vice versa. Soooo, I took off the hose from tubo to intercooler on passenger side & got a pile of oil out of the hose. And that's the one that [******] supposedly fixed. Since I got the car back from him, I have not raced or dyno'd and barely got on it! So did he really fix it?? Well I guess I'll pull the turbo & try & find someone who fixes them. The wheel side is totally dry so it must be the other seal. I do think it's too much pressure going to the turbo. I have to seal my oil dip stick or it blows out of the stick. I even got one of those screw type adapters & it blew thru that too. So I just cap it off with a cap & clamp. I don't know if that relates to the turbo but it's still a hassle! Dan, how far are you from me? Feel like taking a ride down? Thanks for the input guys!
